Split a centerline by point
Available with the Linear Referencing license.
The Split Centerline By Point tool is one of the centerline feature class editing tools available in ArcGIS Linear Referencing. This tool splits a centerline into two contiguous parts at a clicked location on the map. Use this tool to split a centerline at a snapped feature, such as an intersection, county boundary, or railroad crossing.
Tip:
ArcGIS Linear Referencing also supports splitting a centerline using a measure value or splitting a multipart centerline into singlepart features.
You can also use the Split tool on the Edit tab to split a centerline. However, if the centerline has z-values populated, use the Split Centerline By Point tool on the Linear Referencing tab.
To split a centerline by point, complete the following steps:
Add the centerline feature class and network feature class to a map in ArcGIS Pro.
You can also open a map in which the centerline and network feature classes are already present.
In the LRS data model, only one centerline can exist at any given location. Ensure that the centerlines used for your edit do not overlap other centerlines in the LRS.
Branch versioned networks, including any network configured with a user-generated route ID, must be edited through a feature service.
Zoom to the centerline that you want to split.
On the Linear Referencing tab, in the Centerline Editing group, click Split Centerline, and click Split Centerline By Point
.A cross pointer
replaces the cursor.Tip:
Place the cross pointer
over the location to edit to display route and measure information on the map. The route and measure update as you move the pointer. If multiple routes and measures exist at a location, they all appear.If only one applicable route exists at the edit location, click to split the centerline at that point. If multiple routes are applicable, click the location and choose one of the applicable centerlines from the Select Centerline dialog box.
You can set map scale options for display of route and measure information in the Linear Referencing options.
To search for a route and locate measures on it, click Locate Route and Measures
in the Route Identification group on the Linear Referencing tab.
Click a point on the centerline where you want to split it.
If the centerline has additional modeled fields, the centerlines resulting from the split inherit those attribute values.
In a combined LRS and utility network dataset, splitting centerlines with associated routes updates the route ID, start measure, and end measure fields of the centerlines.
If a message about acquiring locks appears, it means that conflict prevention is enabled.
After you select a route, the tool attempts to release the route lock if the active user acquires the route lock in a different named version and the releasable status value is Yes.
The centerline on both sides of the split location flashes in cyan and the centerline splits into two parts.
