Concepts and operations
Various tools and operations are included with a utility network to help manage subnetworks.
Set a subnetwork controller—Use the Modify Subnetwork Controller pane to create a subnetwork and write a new row to the Subnetworks table.
Validate a network topology—Modified features are updated in the network topology and the subnetwork is marked as dirty.
Update a subnetwork—To clean a dirty subnetwork, the Update Subnetwork tool is used to refresh subnetwork information on features.
Modify a subnetwork—The Modify Subnetwork Controller pane allows you to change the name of a subnetwork or remove an existing subnetwork controller from the subnetwork.
Identify isolated features—The Update Is Connected geoprocessing tool can be used to identify isolated network features and objects by maintaining information about their connectivity to subnetwork controllers.
Find Subnetworks pane—The Find Subnetwork pane allows you to locate and interact with subnetworks in your utility network.
Import subnetwork information—Information about which terminal on a network feature is a subnetwork controller can be imported into a utility network through a
.csvfile.Export subnetwork information—Information about subnetworks and subnetwork controllers can be exported from a utility network through a
.jsonfile.
