Subnetworks table
The Subnetworks table stores information about all the existing and deleted subnetworks in a utility network. Each row represents a subnetwork controller and information about its subnetwork. Information in the Subnetworks table is updated when the subnetwork is updated, when the topology is enabled or validated, and when changes are made to a subnetwork. To learn more, see Concepts and operations.
The Subnetworks table is a system-maintained table and is read-only.
The Subnetworks table stores information about the following:
The subnetwork controller or controllers defining a subnetwork
The tier to which a subnetwork belongs
Whether a subnetwork is clean, dirty, or invalid
Whether the terminal on a device feature or nonspatial junction object is removed (is deleted = true) as being a subnetwork controller
The last time information about a subnetwork was exported
Editor tracking details
See View the Subnetworks table for more information on how to access the Subnetworks table.
The Subnetworks table has the following attributes:
Tip:
The Subnetworks table can be ordered by the Subnetwork name column to group all subnetwork controllers belonging to a single subnetwork, or you can use Tier name to show all subnetworks belonging to a specific tier.
Field name |
Field alias |
Description |
Object ID |
The object ID for the record in the table. |
Subnetwork controller name |
The name of the subnetwork controller device or junction object. |
Tier rank |
The rank number assigned to the tier to which the subnetwork belongs. |
Tier name |
The name of the tier to which the subnetwork belongs. |
Tier topology type |
The topology type of the tier to which the subnetwork belongs. |
Feature Global ID |
The global ID of the feature class to which the controller device or junction object belongs. |
Feature asset group |
The name of the asset group to which the subnetwork controller belongs. |
Feature asset type |
The name of the asset type to which the subnetwork controller belongs. |
Feature network source id |
The name of the class for the subnetwork controller. |
Last update subnetwork |
The last time the subnetwork was updated using the Update Subnetwork tool. |
Last ack export subnetwork |
The last time the subnetwork was exported using the Export Subnetwork tool. Note:This attribute is only updated when the Set export acknowledgement check box on the tool is checked. |
Domain network name |
The domain network to which the subnetwork controller belongs. |
Is dirty / Status (for newly created utility networks) |
The |
Is deleted |
Indicates whether the terminal on the subnetwork controller still exists as a subnetwork controller. True means the terminal has been removed and is no longer set as a subnetwork controller, while false means it is set as a subnetwork controller. To delete an entire subnetwork from the table, all the associated subnetwork controllers that define the subnetwork (have the same subnetwork name) must return true for Note:When the update subnetwork policy for a tier is configured to not manage the |
Subnet line global ID |
The global ID of the record in the SubnetLine feature class associated with the subnetwork. |
Description |
The description associated with the subnetwork controller. |
Notes |
Notes assigned to the subnetwork controller. |
Subnetwork name |
The name of the subnetwork. |
Feature terminal ID |
The terminal ID of the terminal set as a subnetwork controller device or junction object. |
Creation date |
The date the terminal was set as a subnetwork controller. |
Creator |
The user who created the subnetwork controller. |
Last update |
The last time the row in the table was updated. |
Updated by |
The last user to update a row in the table. |
Global ID |
The global ID of the row in the table. |
