Project and application options for editing
Project and application options allow you to customize default settings for ArcGIS Pro. The default settings for editing feature data are available in the project Options dialog box on the Editing side tab.
When you customize options for editing, consider the following:
  • Project options apply only to the currently opened project. If there is no open project, they are not enabled.
  • Application options apply to all new projects. They affect the active project and existing projects when you reopen them.
  • To set preferences for field mapping, snapping, the reference grid, and constraint modes, click Editor Settings on the Edit ribbon tab, in the Manage Edits group.
For quick access to options for editing, click the Editing Options dialog box launcher on the Edit ribbon tab, in the Manage Edits group.
Units
Project unit options define the units of measurement that are available to editing tools in a map or a scene. They allow you to edit or digitize data using units that are different than the source feature data. These settings are available on the Options dialog box on the Units tab.
For steps to add or change units for editing, see Set unit options for editing.
Versioning
Versioning options allow you to set the versioning type and conflict resolution method for workflows that edit isolated versions of data and merge the changes back to a published version. These settings are available on the Options dialog box on the Versioning tab.
For steps to change versioning settings, see Set versioning options.
Selections
Selection options set the default behavior for interactive selection tools. These settings are available on the Options dialog box on the Selection tab.
For a quick reference for setting selection options used most when editing feature data, see Set selection options for editing.
Administrator settings
Administrator settings are subsets of the project and application options that can be programmatically set by a system administrator. They are noted in the following tables. If a setting appears locked in the Options dialog box, consult your system administrator.
For a list of administrator settings for editing sessions, see Editing settings.
Edit sessions
Edit session options allow you to either keep editing tools enabled or manually enable them on the ribbon Edit tab and run a Multiple workspace edit session or a Single workspace edit session.
For steps to change edit session options, see Set edit session options .
Setting
Enable or disable editing from the Edit tab
Requires editing tools to be manually enabled and disabled on the Edit ribbon tab and must be set to run multiple or single workspace edit sessions.
Turn off this option to keep editing tools enabled and allow ArcGIS Pro to automatically manage workspace edit sessions. This is the default setting.
Verified
Sets the option for manually enabling editing tools to allow ArcGIS Pro to select a workspace and automatically start an edit session when data is created or modified. The edit session automatically stops when edits are saved or discarded.
This setting is available when the Enable or disable editing from the Edit tab option is enabled.
Sets the option for manually enabling editing tools to require workspaces to be manually selected with the Choose Workspace dialog box each time editing tools are enabled on the Edit ribbon tab. An edit session starts immediately when the workspace is selected and stops when the editing tools are disabled.
Verified
This administrator setting works in conjunction with the administrator setting for Enable or disable editing from the Edit tab. If it is not set, then multiple workspace edit sessions is enabled by default.
Layer editability
The layer editability option allows you to automatically enable or disable layer editability in the Contents pane when you add a layer to a map or a scene.
For steps to change this setting, see Set options for editing layers.
Setting
Make newly added layers editable by default
Automatically enables the editing check box in the Contents pane for an editable layer when it is added to a map or a scene.
Verified
Saving edits
Application options for saving edits include warning prompts for saving and discarding edits and tool deactivation when edits are saved or discarded.
For steps to change these settings, see Set options for saving edits.
Setting
Automatically save edits
Automatically saves edits at recurring intervals specified as minutes or number of operations.
Verified
Save edits when saving a project
Automatically saves edits when a project is saved.
Verified
Show dialog to confirm save edits
The Save Edits dialog box appears and requires edits to be confirmed or cancelled when the Save Edits command is clicked.
Verified
Show dialog to confirm discard edits
The Discard Edits dialog box appears and requires edits to be confirmed or cancelled when the Discard Edits command is clicked.
Verified
Deactivate an active editing tool when saving or discarding
Automatically deactivates the active editing tool and runs the Explore tool when edits are saved or discarded.
Attributes
Application options for editing attributes include settings to enforce attribute validation and set warning prompts for editing attributes and subtypes in the Attributes pane.
For steps to change these settings, see Set editing attributes options.
Setting
Enforce Attribute validation
Restricts edits to values that satisfy the validation criteria defined for a field.
Verified
Auto Apply attribute edits
Sets the default position of the Auto Apply toggle button in the Attributes pane.
Verified
Highlight layer on selection change
Highlights the source layer in the selection view by default when features are selected.
Verified
Warn on subtype change
The Change Subtype dialog box requires edits to be confirmed or cancelled when a subtype value is changed.
Uncommitted attribute edits
The Attributes dialog box requires edits to be applied or cancelled if Auto Apply is turned off and the selection is changed while a field contains uncommitted edits. It can be configured to always appear or never appear and silently apply or discard uncommitted edits.
Verified
Geometry
Application options for editing geometry include default settings for the stretch button on the editing toolbar and warning prompts when editing geometry.
For steps to change these settings, see Set options for editing geometry
Setting
Merge z-aware polygons and allow non-planar geometry
Allows nonplanar geometry to be created when overlapping z-aware polygons are merged with edges at different elevations.
Stretch geometry proportionately when moving vertex
Preserves the general shape of a feature by scaling the relative lengths of its segments when an edge or vertex is moved.
Stretch topology proportionately when moving a topology element
Preserves the general shape of connected topological elements by scaling the relative lengths of its edges when an edge or vertex is moved.
Uncommitted geometry edits
The active tool dialog box requires the results of an active sketch tool to be applied or discarded if another sketch tool is activated before a sketch is finished. It can be configured to always appear or never appear and silently apply or discard the results of the active sketch tool.
Verified
Productivity
Application options for productivity set default behavior for a variety of tools including the move tool, double-clicking to finish geometry, prompting when deleting features, touch screen input, and the default editing tool.
For steps to change these settings, see Set editing productivity options.
Setting
Activate Move tool after all paste operations
Automatically runs the Move tool after pasting features and enables the active move tool option.
Verified
Show feature symbology in the sketch
Draws actively sketched feature geometry using the current feature symbology.
Enable double-click as a shortcut for the Finish button
Runs the Finish command when you double-click a map while drawing a feature with the pointer.
Enable vertex editing while sketching
Allows the vertices of an unfinished line or polygon feature to be modified while the geometry is sketched.
Show dialog to confirm deleting data
The Delete dialog box appears and requires edits to be confirmed or cancelled when the Delete command is clicked.
Verified
Touch screen input for new features
If a device is touch-enabled, allows features to be created by touching the screen in addition to using the mouse and keyboard.
Show the editing toolbar on the map
The editing toolbar appears when its associated editing tool is active. You can configure its size and location.
Default tool when deactivating editing tools
Sets the default tool to either the Explore tool or the Select tool when an editing tool is deactivated.
Follow feature annotation
Application options for editing follow feature annotation include default settings for placement, orientation, and curved annotation that follows the contours of a feature.
For steps to change these settings, see Set follow feature options.
Setting
Automatically follow linked line features
Sets feature-linked annotation to automatically follow its associated line features.
Automatically follow linked polygon features
Sets feature-linked annotation to automatically follow its associated polygon features.
Use placement properties defined in the annotation class
Places feature-linked annotation using the placement properties defined in the source annotation feature class.
Make annotation parallel Parallel
Aligns straight annotation parallel to a feature by default. When annotation is created, this can be overridden on the toolbar and changed to perpendicular.
Make annotation perpendicular Perpendicular
Aligns straight annotation perpendicular to a feature by default.
Make annotation curved Curved
Aligns curved annotation to follow the contours of a feature. This setting disables Parallel/Perpendicular that appears on the toolbar.
Constrain Placement Side cursor is on Cursor side
Dynamically constrains annotation to follow the pointer as you hover to either side of a segment. This setting disables Left/Right that appears on the toolbar.
Constrain placement Left Left side
Constrains annotation to the left side of the feature based on the direction of the segment.
Constrain placement Right Right side
Constrains annotation to the right side of the feature based on the direction of the segment.
Constrain placement On Line On the line
Constrains annotation centered on the feature segment. This setting disables Left/Right that appears on the toolbar.
Sketch symbology
Application options for sketch symbology define the appearance of vertices, segments, and control points for active sketch geometry.
For steps to customize sketch vertices or segments, see Set sketch symbology options.
Vertices
Setting
Vertex unselected Form
Marker symbol
Vertex unselected Color
Marker symbol fill color
Vertex unselected Outline color
Marker symbol outline color
Vertex unselected Outline width
Marker symbol outline width
Vertex unselected Size
Marker symbol size
Vertex unselected Angle
Marker symbol angle
Vertex selected Form
Marker symbol
Vertex selected Color
Vertex selected Outline color
Vertex selected Outline width
Vertex selected Size
Marker symbol size
Vertex selected Angle
Marker symbol angle
Current vertex unselected Form
Marker symbol
Current vertex unselected Color
Current vertex unselected Outline color
Current vertex unselected Outline width
Current vertex unselected Size
Marker symbol size
Current vertex unselected Angle
Marker symbol angle
Current vertex selected Form
Marker symbol
Current vertex selected Color
Current vertex selected Outline color
Current vertex selected Outline width
Current vertex selected Size
Marker symbol size
Current vertex selected Angle
Marker symbol angle
Segments
Setting
Segments primary color
Fill color
Segments secondary color
Segments width
Control points
Application options for control points allow you to enable or disable control points and customize how they appear with sketch geometry.
For steps to change these settings, see Enable control points or change symbology.
Setting
Enables and disables the display of control points.
Control point unselected Form
Marker symbol
Control point unselected Color
Control point unselected Outline color
Control point unselected Outline width
Control point unselected Size
Marker symbol size
Control point unselected Angle
Marker symbol angle
Control point selected Form
Marker symbol
Control point selected Color
Control point selected Outline color
Control point selected Outline width
Control point selected Size
Marker symbol size
Control point selected Angle
Marker symbol angle
