Extend a route
Available with Location Referencing license.
Extending a route in ArcGIS Pipeline Referencing involves adding length to the beginning or end of the route. As with other route editing activities, centerlines provide the location and geometry to extend a route.
The centerline features you use to extend routes can be existing features in the centerline feature class, be digitized into the centerline feature class (using aerial photography, satellite imagery, or other basemaps for guidance), be copied and pasted from other feature classes, or be imported from CAD files or other ArcGIS-supported data sources. In addition to extending a route, the Extend Route tool can update the calibration points.
  • For an engineering network, if the From Measure or To Measure values of the extended section of the route results in an equation point, the route is not extended. Routes must be created using the Create Route tool.
    As shown in the examples below, in the first case, the route has measures from 0 feet to 10 feet. The geometric length of the centerline used for extension is 10 feet. When you extend the route from the beginning, the measures for the extended section start at 0 feet and end at 10 feet.
    Example 1: Before extending a route at beginning
    • If the Recalibrate route downstream option is checked, the original part of the route is recalibrated, and the resulting extended route has measures from 0 feet to 20 feet:
      Example 1: After extending the route at the beginning, it is recalibrated downstream
    • If the Recalibrate route downstream option is not checked, the measures for the extended section that start at 0 feet and end at 10 feet result in an equation point, and the route is not extended. Routes must be created using the Create Route tool.
    In the second case, for an engineering network, the route has measures that go from 0 feet to 10 feet. The geometric length of the centerline used for extension is 10 feet.
    Example 2: Before extending a route at end
    When you extend the route from the end, if you set the measures for the extended section to start at 5 feet and end at 15 feet, this results in an equation point where the centerline and the original route meet. At this equation point, the back station is 10 feet and the ahead station is 5 feet. In this case, the route is not extended. Routes must be created using the Create Route tool.
  • Gap calibration rules are followed when editing routes.
Route extension workflow
To extend a route, complete the following steps:
  1. Add the centerline and network feature class to a map.
    Alternatively, open a map in which the centerline and network feature class are present.
    • In the LRS data model, only one centerline is expected at any given location. Ensure that the centerlines used for your edit do not overlap other centerlines in the LRS.
    • Branch versioned networks, including any network configured with a user-generated route ID, must be edited through a feature service.
  2. Zoom in to the location where you want to extend a route.
    The centerline features used for extending a route must exist in the centerline feature class before extending a route.
  3. On the Location Referencing tab, in the Routes group, click Extend .
    Extend button
    The Extend Route pane appears with the Select By Rectangle tool active by default.
    You can use multiple centerlines to extend a route.
  4. Use your pointer to select one or more centerlines on the map by rectangle at the location of the route you want to extend.
    You can also click the Select one or more centerlines drop-down arrow and choose one of the other selection tools: Select By Polygon , Select By Lasso , Select By Circle , Select By Line , or Select By Trace .
    Alternatively, you can use the interactive selection tools on the Map tab.
    The selected centerlines are highlighted on the map and the Allow choosing of one or more centerlines button appears in the Extend Route pane. The Selected Centerlines count is shown above the table.
    • The direction of digitization determines the direction of calibration, increasing in the direction of digitization. You can reverse direction for the chosen centerlines using the Flip the direction of the centerlines button . This leads to an in-memory flip of the centerlines' direction and the change in direction is not permanent.
    • If the centerlines do not touch the route at the extended location, click the Extension Location drop-down arrow and choose Begin or End.
    • You can keep the centerlines chosen after creating the route by checking the Keep centerlines chosen and selected check box in the Location Referencing options.
    • If the centerline was created as a curve, Pipeline Referencing will convert the curve into a densified polyline feature.
  5. Click Allow choosing of one or more centerlines .
    A table appears in the Extend Route pane with each chosen centerline in a numbered row that corresponds to the selection order. The chosen centerlines are numbered on the map and highlighted. The Chosen Centerlines count is shown below the table.
    Extend Route pane with multiple centerlines chosen
    The Recalibrate route downstream check box appears only when the route is extended at the beginning of an engineering network. If this option is checked, the measures downstream of the extension are updated.
  6. Optionally, choose one or more rows from the Order column, and use the buttons below the table to change the centerline selection order. You can also drag rows to change the order.
    Changes in the table selection order are also shown on the map.
    Tools available in the centerlines table
    Tool
    Tool name
    Tool description
    Allows you to choose the centerlines on the map and displays them in a table by order of selection. Use the move buttons below the table or drag rows to reorder the chosen centerlines.
    Clear the currently chosen centerlines
    Clears the chosen centerlines and keeps the selected centerlines. You can reselect after clicking this button or click the Allow choosing one or more centerlines button a second time.
    Move chosen centerlines up
    Moves one or more selected centerlines up a row in the table order.
    Move chosen centerlines to the top
    Moves one or more centerlines to the top of the table order.
    Move chosen centerlines down
    Moves one or more centerlines down a row in the table order.
    Move chosen centerlines to the bottom
    Moves one or more centerlines to the bottom of the table order.
    Reverses the direction of the chosen centerlines. This leads to an in-memory flip of the centerlines' direction and the change in direction is not permanent.
    Remove the chosen centerlines
    Removes the chosen centerline from the table order but leaves it selected.
    Tip:
    To change the display field in the centerlines table, right-click the centerline feature class in the Contents pane, and choose Properties from the context menu. On the Layer Properties dialog box, click the Display tab, and click the Display field drop-down arrow to change its value. In the previous image, the display field is OBJECTID.
  7. Choose the network in which you want to extend a route.
    To edit using feature services, the LRS Network must be published with the Linear Referencing and Version Management capabilities.
  8. Click Choose route from map to choose a route to extend.
    After clicking the Choose route from map button , you can hover over the routes to see the route and measure at the location of the pointer.
    If only one applicable route exists at the edit location, click to select it. If multiple routes are applicable, click to select one of the applicable routes using the Select Route dialog box.
    You can set map scale options for display of route and measure information in the Location Referencing options.
    Tip:
    You can't extend a route to fill a gap between routes.
  9. Click the Calendar and choose a start date.
    • Alternatively, provide the date in the Effective Date text box.
    • Double-click the empty Effective Date text box to populate today's date.
  10. Verify that the automatically populated From Measure value appears as expected in the Extended Section section.
    • If the route is being extended at the end, the suggested From Measure value is the same as the To Measure value of the original route.
    • If the route is being extended from the beginning, the suggested From Measure value is 0.
  11. Alternatively, you can provide a From Measure value.
    If you do not know the start measure, allow Pipeline Referencing to suggest it. Click Recalculate From Measure to do so. This value is calculated as the difference between the To Measure value and the geometric length of the centerline.
    For engineering networks, the measures can be entered as station values in 00+00.00 or 00+00.000 format.
  12. Verify that the automatically populated To Measure value appears as expected in the Extended Section section.
    • If the route is being extended at the end, the suggested To Measure value is the suggested From Measure value plus the geometric length of the centerline.
    • If the route is being extended from the beginning, the suggested To Measure value is the suggested From Measure value plus the geometric length of the centerline.
  13. Alternatively, you can provide a To Measure value of your choice.
    If you do not know the end measure, allow Pipeline Referencing to suggest it. Click Recalculate To Measure to do so. This value is calculated as the sum of the From Measure value and the geometric length of the centerline.
  14. Click Run.
    The route is extended. The original route is retired with its To Date field populated with the Effective Date value. A newly extended route is created with its From Date field populated with the Effective Date value, and the To Date field populated with a null value.
    • If the route edit will result in the introduction of one or more physical gaps on the route, a prompt appears to alert you before the tool is run. If you don't plan to create a gapped route, click No.
    • If the route being edited already had one or more physical gaps, and no more physical gaps were introduced by the edit, no prompt appears.
    • You can disable this warning by unchecking the Warn before allowing route edits that can create physical gaps check box in the Location Referencing options.
    • If a message regarding acquiring locks or reconciling appears, conflict prevention is enabled. After a route is selected, the tool will attempt to release the route lock if the route lock is acquired by the active user in a different version and its releasable status value is Yes.
Route extension in a utility network dataset
After configuring a utility network for use with an LRS using the Configure Utility Network Feature Classes tool, use the steps above to extend routes.
The centerlines used to extend a route can have measure values populated before route editing. The coincident points of the centerline features must have the same measures.
If the measures are not provided using the centerline feature class, the LRS route editing tools provide start and end measures on the route.
In the following example, RouteX can be extended at the beginning using centerlines CL1 and CL2 since their start and end measures match. Calibration points are created at the end of each centerline when RouteX is extended.
Example 1: Start and end measures of CL1 and CL2 match; the route is extended and new calibration points are added.
In the following example, RouteX can’t be extended at the beginning using centerlines CL1 and CL2 because the start and end measures of CL2 and CL3 don’t match.
Example 2: Start and end measures of CL2 and CL3 don't match; the route is not extended.
In the following example, RouteX can’t be extended at the beginning using centerlines CL1 and CL2. Even though the coincident points of the centerlines match, the order of their selection (CL2 followed by CL1) causes the extended portion of RouteX to be nonmonotonic.
Example 3: The order of selection, CL2 followed by CL1, causes a nonmonotonic route; the route is not extended.
In the following example, RouteX can’t be extended at the beginning using centerlines CL1 and CL2. Even though the coincident points of the centerlines match, the start and end measures of CL2 are the same (19) and cause the extended portion of RouteX to be nonmonotonic.
Example 4: Starting and ending measures of CL2 are the same and cause a nonmonotonic route; the route is not extended.
In the following example, RouteX can’t be extended at the beginning using centerlines CL1 and CL2. Even though the coincident points of the centerlines match, the direction of CL2 is the opposite direction to that of the route.
Example 5: The direction of CL2 is opposite to the direction of the route; the route is not extended.
