ArcGIS.Desktop.Framework.Contracts Namespace / ConfigurationManager Class
    ConfigurationManager Class Methods
    For a list of all members of this type, see ConfigurationManager members.
    Protected Methods
     NameDescription
    Protected Internal Method Called when the application is initializing. It is safe to communicate with Portal at this time. The DAML records have not been processed at this point.
    Protected Internal Method Called when the appliation has fully initialized.
    Protected Internal Method Gives a configuration the ability to disable commands.
    Protected Internal Method Opportunity for the configuration to provide DAML at run-time.
    Protected Internal Method The list of commands to show in the quick access toolbar.
    Protected Internal Method Allows a configuration to reject a command's execution.
    Protected Internal Method Allows the configuration to inject some custom user interface into the about page.
    Protected Internal Method The custom splash screen for the configuration.
    Protected Internal Method The custom start page (landing page) to show once the appliation starts.
    Protected Internal Method Called when web help is requested.
    Protected Internal Method The last chance for the configuration to manipulate the DAML before it is processed.
    Protected Internal Method Gives the configuration the chance to perform its own license checking. Returning false signals a licensing problem has occurred and the application should shut down.
    Top
