ArcGIS.Desktop.Framework.Contracts Namespace / Gallery Class
    Gallery Class Properties
    For a list of all members of this type, see Gallery members.
    Public Properties
     NameDescription
    Public Property Gets or sets the boolean to fire the click event even if the item is currently selected. The default value is false.
    Public Property Gets or sets the command label as it appears in the ribbon and customize dialog. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property InRibbonGallery's bounded ItemSource. This collection filters out the items whose value of IGalleryItem.IsGroupVisible is false.
    Public PropertyGets or sets the supplementary text that appears with the Tooltip only when the command is disabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a boolean to specify whether the control is enabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets the DAML identifier. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets the gallery's items.
    Public Property Gets a copy of the gallery's items which is safe to iterate over from any thead.
    Public Property Gets or sets the custom item template.
    Public Property Gets or sets the large representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets the message to show while items are loading into collection.
    Public Property Gets or sets the zero-based index of the selected item.
    Public Property Gets or sets the selected gallery item.
    Public Property Gets or sets the small representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a brief description of the command that appears in a small pop-up window when a user pauses the mouse pointer over an element, such as over a Button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a one or two word label that appears above the tooltip. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Top
    Protected Properties
     NameDescription
    Protected Internal Property Gets or sets default gallery groups or items used to restore the dialog. This is necessary for gallery customization dialog.
    Protected Property Gets or sets the flag indicating the gallery has not initialized properly.
    Top
