ArcGIS.Desktop.Framework.Contracts Namespace / PaneBase Class
    PaneBase Class Properties
    For a list of all members of this type, see PaneBase members.
    Public Properties
     NameDescription
    Public Property Gets or sets the command label as it appears in the ribbon and customize dialog. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public PropertyGets or sets the supplementary text that appears with the Tooltip only when the command is disabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a boolean to specify whether the control is enabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets the DAML identifier. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets a boolean indicating whether the pane has been fully initialized or not.
    Public Property Gets or sets the large representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets the small representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a brief description of the command that appears in a small pop-up window when a user pauses the mouse pointer over an element, such as over a Button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Public Property Gets or sets a one or two word label that appears above the tooltip. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Top
