ArcGIS.Core.CIM Namespace / CIMDocumentInfo Class
Properties Methods Events
    CIMDocumentInfo Class Members
    The following tables list the members exposed by CIMDocumentInfo.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the path of the active map.
    Public Property Gets or sets the anti-aliasing properties. Currently overridden by application settings.
    Public Property Gets or sets the author of the document.
    Public Property Gets or sets the build an item was created with. Set by the system. (Inherited from ArcGIS.Core.CIM.CIMVersion)
    Public Property Gets or sets the category of the document.
    Public Property Gets or sets the comments of the document.
    Public Property Gets or sets the credits of the document.
    Public Property Gets or sets the title of the document.
    Public Property Gets or sets the hyperlink base path of the document.
    Public Property Gets or sets the keywords of the document.
    Public Property Gets or sets a value indicating whether to save a preview image.
    Public Property Gets or sets the subject of the document.
    Public Property Gets or sets the text anti-aliasing properties. Currently overridden by application settings.
    Public Property Gets or sets a value indicating whether to save with relative paths. In typical Pro usage (e.g. saving projects or .lyrx files) this is set to true.
    Public Property Gets or sets document version. Set by the system. (Inherited from ArcGIS.Core.CIM.CIMVersion)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMDocumentInfo.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMDocumentInfo with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMDocumentInfo and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
