ArcGIS.Core.CIM Namespace / CIMExtentIndicator Class
Properties Methods Events
    CIMExtentIndicator Class Members
    The following tables list the members exposed by CIMExtentIndicator.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether to avoid label conflict. Reserved for future implementation.
    Public Property Gets or sets the minimum size of the extent indicator before symbolizing it as a point. Units in points.
    Public Property Gets or sets the extent indicator type. Reserved for future implementation at this time.
    Public Property Gets or sets a value indicating whether the extent indicator is visible.
    Public Property Gets or sets the leader symbol used to connect the associated extents.
    Public Property Gets or sets the leader style used to connect the associated extents.
    Public Property Gets or sets the name of the extent indicator.
    Public Property Gets or sets the point symbol used to symbolize an extent indicator.
    Public Property Gets or sets the source map frame's extent to be displayed.
    Public Property Gets or sets the area symbol used to represent the extent indicator.
    Public Property Gets or sets a value indicating whether the area symbol should be applied outside the extent.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMExtentIndicator.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMExtentIndicator with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMExtentIndicator and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
