ArcGIS.Core.CIM Namespace / CIMS52TextGroupVisibilitySettings Class
Properties Methods Events
    CIMS52TextGroupVisibilitySettings Class Members
    The following tables list the members exposed by CIMS52TextGroupVisibilitySettings.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether the "berth number" text group should be visible.
    Public Property Gets or sets a value indicating whether the "current velocity" text group should be visible.
    Public Property Gets or sets a value indicating whether the "geographic names" text group should be visible.
    Public Property Gets or sets a value indicating whether the "height of islet or land feature" text group should be visible.
    Public Property Gets or sets a value indicating whether the "important text" text group should be visible.
    Public Property Gets or sets a value indicating whether the "light descriptions" text group should be visible.
    Public Property Gets or sets a value indicating whether the "magnetic variation and swept depth" text group should be visible.
    Public Property Gets or sets a value indicating whether the "names for position reporting" text group should be visible.
    Public Property Gets or sets a value indicating whether the "nature of seabed" text group should be visible.
    Public Property Gets or sets a value indicating whether the "note on chart data" text group should be visible.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMS52TextGroupVisibilitySettings.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMS52TextGroupVisibilitySettings with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMS52TextGroupVisibilitySettings and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
