ArcGIS.Core.CIM Namespace / CIMGAIsoRenderer Class
Properties Methods Events
    CIMGAIsoRenderer Class Members
    The following tables list the members exposed by CIMGAIsoRenderer.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether or not to automatically update class labels whenever a class upper value is changed. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the additional authoring information used by the renderer. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the background symbol used for graduated symbols. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the barrier weight used for graduated symbols to avoid labels. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the class breaks. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the class break type. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the classification method. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the color ramp. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the default description. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the default label. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the default symbol. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the custom patch for the default symbol. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the patch shape for the default symbol. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets a value indicating whether or not to draw graduated symbols for polygon features above all layers. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the field for rendering. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the heading. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the iso quality.
    Public Property Gets or sets the iso type.
    Public Property Gets or sets the minimum break. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the minimum label. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the no result symbol.
    Public Property Gets or sets the number format. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the property that controls how the color ramp is applied to polygon symbols. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets a value indicating whether to refine on zoom.
    Public Property Gets or sets the maximum number of records to sample. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets a value indicating whether or not to show class gaps. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets a value indicating whether or not to show classes in ascending order. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets a value indicating whether or not to use the default symbol. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets ExpressionInfo that contains the Arcade expression that returns value as a number. When both Fields and ValueExpressionInfo are present ValueExpressionInfo is used. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMGAIsoRenderer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMGAIsoRenderer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMGAIsoRenderer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
