ArcGIS.Core.Data Namespace / FileSystemDatastore Class
    FileSystemDatastore Class Methods
    For a list of all members of this type, see FileSystemDatastore members.
    Public Methods
     NameDescription
    Public Method Gets a value indicating whether this datastore supports datastore properties. (Inherited from ArcGIS.Core.Data.Datastore)
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets the connection string associated with the currently opened data store (e.g., an enterprise geodatabase). This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Datastore)
    Public MethodOverridden. Gets the Connector associated with the currently opened file-system data store. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the datastore properties of the datastore. (Inherited from ArcGIS.Core.Data.Datastore)
    Public MethodGets a specific Definition instance associated with name of type T in the file-system data store. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the path to the currently opened data store (e.g., an enterprise geodatabase .sde connection file). This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Datastore)
    Public MethodGets the gateway to access information about the SQL syntax and other functionality supported by this Datastore. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Datastore)
    Public Method Determines whether the currently opened data store (e.g., an enterprise geodatabase) has any pending edits which have not been saved. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Datastore)
    Public MethodGets a specific Dataset instance associated with name of type T in the file-system data store. This method must be called on the MCT. Use QueuedTask.Run.
    Top
