ArcGIS.Core.CIM Namespace / CIMGeometricEffectCut Class
Properties Methods Events
    CIMGeometricEffectCut Class Members
    The following tables list the members exposed by CIMGeometricEffectCut.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the distance from the beginning of a line that the display of the stroke starts. The beginning of the line is determined by the direction in which the line was digitized.
    Public Property Gets or sets the distance from the end of a line that the display of the stroke ends. The end of the line is determined by the direction in which the line was digitized.
    Public Property Gets or sets a value indicating whether the effect should be applied in the opposite manner. This displays the stroke symbol only at the ends of the line and leaves the rest of the line unsymbolized.
    Public Property Gets or sets the distance around the middle of a line that the display of the stroke is interrupted.
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMGeometricEffect)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMGeometricEffectCut.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMGeometricEffectCut with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMGeometricEffectCut and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
