ArcGIS.Core.CIM Namespace / CIMGeometricEffectExtension Class
Properties Methods Events
    CIMGeometricEffectExtension Class Members
    The following tables list the members exposed by CIMGeometricEffectExtension.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the deflection angle used for the extension. A value of 0 indicates no deflection.
    Public Property Gets or sets the length of the extension that is dynamically created.
    Public Property Gets or sets the origin of the extension to add to the line. The beginning and end of the line is defined by the direction the line was digitized.
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMGeometricEffect)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMGeometricEffectExtension.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMGeometricEffectExtension with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMGeometricEffectExtension and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
