ArcGIS.Core.CIM Namespace / CIMColorClassBreaksVisualVariable Class
Properties Methods Events
    CIMColorClassBreaksVisualVariable Class Members
    The following tables list the members exposed by CIMColorClassBreaksVisualVariable.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether or not to automatically update class labels whenever a class upper value is changed.
    Public Property Gets or sets the authoring info. (Inherited from ArcGIS.Core.CIM.CIMVisualVariable)
    Public Property Gets or sets the class breaks.
    Public Property Gets or sets the legend display options.
    Public Property Gets or sets the classification method.
    Public Property Gets or sets a value indicating which channels of the color model will be overridden by the visual variable.
    Public Property Gets or sets the color ramp. (Inherited from ArcGIS.Core.CIM.CIMColorVisualVariable)
    Public Property Gets or sets the default description.
    Public Property Gets or sets the default label.
    Public Property Gets or sets the default symbol.
    Public Property Gets or sets the custom patch for the default symbol.
    Public Property Gets or sets the patch shape for the default symbol.
    Public Property Gets or sets the expression. (Inherited from ArcGIS.Core.CIM.CIMColorVisualVariable)
    Public Property Gets or sets the maximum value. (Inherited from ArcGIS.Core.CIM.CIMColorVisualVariable)
    Public Property Gets or sets the minimum break.
    Public Property Gets or sets the minimum value. (Inherited from ArcGIS.Core.CIM.CIMColorVisualVariable)
    Public Property Gets or sets the normalization field. (Inherited from ArcGIS.Core.CIM.CIMColorVisualVariable)
    Public Property Gets or sets the data normalization method. (Inherited from ArcGIS.Core.CIM.CIMColorVisualVariable)
    Public Property Gets or sets the number format.
    Public Property Gets or sets the property that controls how the color ramp is applied to polygon symbols. (Inherited from ArcGIS.Core.CIM.CIMColorVisualVariable)
    Public Property Gets or sets a value indicating whether or not to show class gaps.
    Public Property Gets or sets a value indicating whether or not to show classes in ascending order.
    Public Property Gets or sets a value indicating whether or not to use class breaks.
    Public Property Gets or sets a value indicating whether or not to use the default symbol.
    Public Property Gets or sets ExpressionInfo that contains the Arcade expression that returns value as a number. (Inherited from ArcGIS.Core.CIM.CIMColorVisualVariable)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMColorClassBreaksVisualVariable.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMColorClassBreaksVisualVariable with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMColorClassBreaksVisualVariable and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
