ArcGIS.Core.CIM Namespace / CIMTiles3DLayer Class
Properties Methods Events
    CIMTiles3DLayer Class Members
    The following tables list the members exposed by CIMTiles3DLayer.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether layer can be draped on integrated mesh. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the attribution text that appears on a map that draws this layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the blending mode for the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets identifier the layer's charts. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the custom properties of the layer. Custom properties are limited to key / value pairs of strings and developers are fully responsible for stored content. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the data connection.
    Public Property Gets or sets the description. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the display cache type. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether to enable any type of effects on the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether this layer is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the 3D layer properties. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the layer effects for the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the layer elevation. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the URIs of the layers used as masks. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the layer's scale visibility options. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the layer template. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the map layer type. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the maximum display cache age. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the maximum scale for layer draw (set as the denominator of the scale's representative fraction). (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the minimum scale for layer draw (set as the denominator of the scale's representative fraction). (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether the modification is enabled.
    Public Property Gets or sets the URI of the modification layer.
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the pop-up info. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether layer should be rasterized when exporting. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the amount of time to wait between refreshing the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the units for the amount of time to wait between refreshing the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether or not this layer should be included in the search. This property is honored only by layers that support search. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets identifier that will be used to identify the layer in server. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether or not to show legends. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether or not the value of the display field or expression is shown when hovering over a layer in the view. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether or not to show pop-ups. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether the geometries are snappable.
    Public Property Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the 3D Tiles layer type. Typically set by the system and should not be modified.
    Public Property Gets or sets the transparency of the layer as a percentage. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether or not to use a fixed time extent for layer visibility. When true, the map time must overlap this extent for the layer to be visible. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether or not this layer is visible. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the fixed time extent for layer visibility. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets an identifier that will be used to identify the layer in a web map. This value is present if the layer originated in a web map and facilitates matching the layer back to its origin when updating the web map. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMTiles3DLayer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMTiles3DLayer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMTiles3DLayer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
