ArcGIS.Core.CIM Namespace / CIMGeometricEffectSuppress Class
Properties Methods Events
    CIMGeometricEffectSuppress Class Members
    The following tables list the members exposed by CIMGeometricEffectSuppress.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether to invert the suppression process. If this value is true, portions of the stroke symbol between control points are kept and all other portions are suppressed.
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMGeometricEffect)
    Public Property Gets or sets a value indicating whether the portion of the stroke symbol between control points should be suppressed. Sections that are suppressed draw with no symbol.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMGeometricEffectSuppress.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMGeometricEffectSuppress with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMGeometricEffectSuppress and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
