ArcGIS.Core.CIM Namespace / CIMGeometricEffectWave Class
Properties Methods Events
    CIMGeometricEffectWave Class Members
    The following tables list the members exposed by CIMGeometricEffectWave.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the distance perpendicular to a feature to display the curves for the symbol.
    Public Property Gets or sets the distance along the line or polygon to display the curves for the symbol.
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMGeometricEffect)
    Public Property Gets or sets the staring value for generating a random number. This is only used when the Waveform is set to Random.
    Public Property Gets or sets the shape of the curves to be displayed along the symbol.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMGeometricEffectWave.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMGeometricEffectWave with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMGeometricEffectWave and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
