| Name | Description | |
![]() | CIMGISProject Constructor |
The following tables list the members exposed by CIMGISProject.
![]() | DatabaseConnections | Gets or sets the database connections of the project. |
![]() | DefaultFolder | Gets or sets the default folder of the project. |
![]() | DefaultGeoDatabase | Gets or sets the path of the default geodatabase of the project. |
![]() | DefaultSpatialReference | Gets or sets a WKT string representation of the default spatial reference of the project. |
![]() | DefaultToolbox | Gets or sets the path of the default toolbox of the project. |
![]() | DisplayUnitSettings | Gets or sets the display unit settings for the project. |
![]() | FolderConnections | Gets or sets the folder connections of the project. |
![]() | ForceUpdate | Gets or sets a value indicating whether to force update an updatable project. |
![]() | ModuleSettings | Gets or sets the module settings of the project. |
![]() | ProjectItems | Gets or sets the items of the project. |
![]() | ProjectMetadata | Gets or sets the path to an XML file in the same folder as the APRX that contains metadata about the project. |
![]() | ReadOnly | Gets or sets a value indicating whether the project is read only for updatable projects. |
![]() | ServerConnections | Gets or sets the service connections of the project. |
![]() | SourceModifiedTime | Gets or sets the time the project was last modified. |
![]() | SourceURI | Gets or sets the source URI of the project. Set if sourced from an external item such as an item on a portal. |
![]() | ThumbnailOptions | Gets or sets the thumbnail generation options for the project. |
![]() | ViewLayoutXML | Gets or sets an XML representation of the view layout used for the project. |
![]() | Views | Gets or sets the views of the project. |
![]() | Clone | Creates a deep copy of CIMGISProject. |
![]() ![]() | FromJson | Reconstructs the CIMGISProject with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the CIMGISProject and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
