| Name | Description | |
![]() | IncludeDomainDescriptions | Specifies whether domain descriptions will be included in the resulting JSON file. (Inherited from ArcGIS.Core.Data.UtilityNetwork.ExportOptions) |
![]() | IncludeFlowDirections | Specifies whether to include flow direction results. |
![]() | IncludeGeometry | Specifies whether geometry will be included in the results. |
![]() | IncludePropagatedValues | Specifies whether to include propagated value results. |
![]() | ResultFieldsByNetworkSourceID | The names of the fields from a network source that will be returned as results. |
![]() | ResultNetworkAttributes | The network attributes that will be included in the results. |
![]() | ServiceSynchronizationType | Specifies if this operation should run asynchronously. (Inherited from ArcGIS.Core.Data.UtilityNetwork.ExportOptions) |
![]() | SetAcknowledged | Specifies whether the export is acknowledged. If true the default version is required. |
![]() | SubnetworkExportResultTypes | Specifies the types of results that will be returned. |
