ArcGIS.Core.CIM Namespace / CIMProfileOIS Class
Properties Methods Events
    CIMProfileOIS Class Members
    The following tables list the members exposed by CIMProfileOIS.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the zero based index to control the display order.
    Public Property Gets or sets a value indicating whether the surface is primary. If surface is primary it can't be hidden and terrain and obstacles will be drawn based on the primary surface.
    Public Property Gets or sets the description of OIS surface read only.
    Public Property Gets or sets the label to be displayed for OIS.
    Public Property Gets or sets the line Symbol used to draw the OIS Surface.
    Public Property Gets or sets the text symbol used to draw the label of OIS Surface.
    Public Property Gets or sets a value indicating whether to show OIS surface.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMProfileOIS.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMProfileOIS with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMProfileOIS and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
