ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphEntityValue Class
Properties Methods
    KnowledgeGraphEntityValue Class Members
    The following tables list the members exposed by KnowledgeGraphEntityValue.
    Public Properties
     NameDescription
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Property Gets and sets the value corresponding to the given key. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Knowledge.KnowledgeGraphObjectValue)
    Public Property Gets the KnowledgeGraph value type. (Inherited from ArcGIS.Core.Data.Knowledge.KnowledgeGraphValue)
    Top
    Public Methods
     NameDescription
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets whether the named graph object has an ObjectID or not. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Knowledge.KnowledgeGraphNamedObjectValue)
    Public Method Gets the ID associated with the named object value. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Knowledge.KnowledgeGraphNamedObjectValue)
    Public Method Gets the set of keys associated with the graph object value. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Knowledge.KnowledgeGraphObjectValue)
    Public Method Gets the label associated with the entity. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the ObjectID or -1 if the named object does not have one. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Knowledge.KnowledgeGraphNamedObjectValue)
    Public Method Gets the named object Type name. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Knowledge.KnowledgeGraphNamedObjectValue)
    Top
