ArcGIS.Core.CIM Namespace / CIMChartLineSeries Class
Properties Methods Events
    CIMChartLineSeries Class Members
    The following tables list the members exposed by CIMChartLineSeries.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether the time interval units and size are automatically calculated.
    Public Property Gets or sets the type of color for the series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the text style for the data label. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the aggregate field values if series data has a group field. Allowed values are count, sum, median, mean, and empty string. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets expression properties for chart series' fields. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the data field names in the series. Optional depending on series type. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the properties of the area fill symbol. This property is only being used if ShowAsArea is true.
    Public Property Gets or sets the group field names in the series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the index of horizontal axis. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the line symbol properties of the line series.
    Public Property Gets or sets the locations for which data is to be plotted. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the marker symbol properties of the line series.
    Public Property Gets or sets the line symbol for the moving average.
    Public Property Gets or sets a period value for moving average calculation.
    Public Property Gets or sets a value indicating whether this series is a multi series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the name of the series shown in the legend. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the policy for handling missing data.
    Public Property Gets or sets the sort field names in the series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the array of sort order types for fields in OrderFields property Allowed values 0(Ascending), 1(Descending). (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the reference time value. Valid when TimeAggregationType property is set to ReferenceTime.
    Public Property Gets or sets a value indicating whether the line series shows as an area.
    Public Property Gets or sets a value indicating whether the series shows data labels. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets a value indicating whether to show a moving average line overlay.
    Public Property Gets or sets a value indicating whether the line is smoothed with curves.
    Public Property Gets or sets the array of sorted category values for custom sort.
    Public Property Gets or sets the type of series stacking.
    Public Property Gets or sets the time aggregation type.
    Public Property Gets or sets the time interval size.
    Public Property Gets or sets the units used for the time interval size.
    Public Property Gets or sets a value indicating whether incomplete time intervals at the ends of time interval ranges are trimmed in order to avoid bias.
    Public Property Gets or sets the default and unique name of the series. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the index of vertical axis. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets a value indicating whether this is a vertical (true) or horizontal (false) orientation of a line series.
    Public Property Gets or sets a value indicating whether the series is visible or not. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Public Property Gets or sets the format string for series value labels. (Inherited from ArcGIS.Core.CIM.CIMChartSeries)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMChartLineSeries.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMChartLineSeries with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMChartLineSeries and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
