ArcGIS.Core.CIM Namespace / CIMDatabaseRelateInfo Class
Properties Methods Events
    CIMDatabaseRelateInfo Class Members
    The following tables list the members exposed by CIMDatabaseRelateInfo.
    Public Constructors
    Public Properties
     NameDescription
    Public PropertyGets or sets the related layer/table URI. This value is used to disambiguate cases where the same data connection is used by multiple layers or tables in a map.
    Public Property Gets or sets the relationship class Name.
    Public Property Gets or sets a integer indicating the relate ID when published in a map service.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMDatabaseRelateInfo.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMDatabaseRelateInfo with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMDatabaseRelateInfo and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
