ArcGIS.Core.CIM Namespace / CIMKeyframeSurface Class
Properties Methods Events
    CIMKeyframeSurface Class Members
    The following tables list the members exposed by CIMKeyframeSurface.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the elevation sources.
    Public Property Gets or sets the id for the surface.
    Public Property Gets or sets the direction to clip from an edge.
    Public Property Gets or sets the amount of the visible area to clip.
    Public Property Gets or sets the method of transition for the surface.
    Public Property Gets or sets the vertical exaggeration for the surface.
    Public Property Gets or sets a value indicating whether the surface is visible.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMKeyframeSurface.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMKeyframeSurface with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMKeyframeSurface and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
