ArcGIS.Core.CIM Namespace / CIMSnowyWeatherEffect Class
Properties Methods Events
    CIMSnowyWeatherEffect Class Members
    The following tables list the members exposed by CIMSnowyWeatherEffect.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the base cloud elevation in meters above sea level.
    Public Property Gets or sets the percentage (0-1) of cloud cover in the sky.
    Public Property Gets or sets a value indicating whether the effect should be applied to the scene. (Inherited from ArcGIS.Core.CIM.CIMWeatherEffect)
    Public Property Gets or sets the percentage (0-1) of snowfall amount in the scene.
    Public Property Gets or sets the starting value for generating a random cloud pattern. (Inherited from ArcGIS.Core.CIM.CIMWeatherEffect)
    Public Property Gets or sets a value indicating whether surfaces are covered with snow.
    Public Property Gets or sets the wind direction (0-359).
    Public Property Gets or sets the wind speed in km/h.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMSnowyWeatherEffect.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMSnowyWeatherEffect with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMSnowyWeatherEffect and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
