ArcGIS.Core.CIM Namespace / NALastMileDeliverySolver Class
Properties Methods Events
    NALastMileDeliverySolver Class Members
    The following tables list the members exposed by NALastMileDeliverySolver.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets and sets the accumulate attribute names. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the applied travel mode. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the applied travel mode as JSON. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the attribute names. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the attribute parameters values. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the directions language. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition)
    Public Property Gets and sets the directions length attribute name. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition)
    Public Property Gets and sets the directions length units. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition)
    Public Property Gets and sets the directions output spatial reference. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition)
    Public Property Gets and sets the directions output type. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition)
    Public Property Gets and sets the directions style name. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition)
    Public Property Gets and sets the directions time attribute name. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition)
    Public Property Gets and sets the distance units.
    Public Property Gets and sets the earliest route start date.
    Public Property Gets and sets the earliest route start time.
    Public Property Gets and sets the name of the hierarchy attribute to be used in analysis. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the hierarchy level count. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the maximum value of the hierarchy attribute. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the number of lower level junctions to explore before searching the next hierarchy level. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets a boolean which indicates whether or not to ignore invalid locations. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the impedance attribute name. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets a boolean indicating whether the input date time fields are in UTC.
    Public Property Gets and sets whether or not to generate directions on solve. (Inherited from ArcGIS.Core.CIM.NADirectionsCapableSolverDefinition)
    Public Property Gets and sets the route maximum total time span in time units.
    Public Property Gets and sets the associated network build hash. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the output geometry precision. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the output geometry precision units. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the type of line(s) generated.
    Public Property Gets and sets a boolean which indicates if the hierarchy ranges will be reset to the network dataset's hierarchy settings when the solver is bound. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the restriction attribute names. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets a setting which indicates how U-Turns should be restricted in the analysis. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the sequence gap inserted between assigned orders.
    Public Property Gets and sets the associated solver overrides. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the time units.
    Public Property Gets and sets a boolean which indicates if the hierarchy attribute for the network should be used in analysis. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Top
    Public Methods
     NameDescription
    Public Methodstatic (Shared in Visual Basic) Reconstructs the NALastMileDeliverySolver with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the NALastMileDeliverySolver and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
