ArcGIS.Core.CIM Namespace / CIMKeyframeCamera Class
Properties Methods Events
    CIMKeyframeCamera Class Members
    The following tables list the members exposed by CIMKeyframeCamera.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the bezier control points between the previous camera position and the current camera position. Used to define the camera path for the AdjustableArc transition. When the value is null or empty, a default path is used. Must be in the map's spatial reference.
    Public Property Gets or sets the camera for the keyframe.
    Public Property Gets or sets the transition mode determines whether the camera path follows a Geodesic or Cartesian interpolation.
    Public Property Gets or sets the field of view angle. Only applies to scene views.
    Public Property Gets or sets the method of transition for the field of view of the camera.
    Public Property Gets or sets the method of transition for the heading of the camera.
    Public Property Gets or sets a geometry for the camera to look at. When a geometry is set it overrides the camera's heading and pitch. Must be in the map's spatial reference.
    Public Property Gets or sets the method of transition for the pitch of the camera.
    Public Property Gets or sets the method of transition for the roll of the camera.
    Public Property Gets or sets the method of transition for the scale of the camera.
    Public Property Gets or sets the value of adjustable transitions. The value must be between 0.0 and 1.0. Smaller values will result in a tighter / smaller curve than larger values.
    Public Property Gets or sets the method of transition for the x of the camera.
    Public Property Gets or sets the method of transition for the y of the camera.
    Public Property Gets or sets the method of transition for the z of the camera.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMKeyframeCamera.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMKeyframeCamera with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMKeyframeCamera and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
