ArcGIS.Core.CIM Namespace / CIMKeyframeRange Class
Properties Methods Events
    CIMKeyframeRange Class Members
    The following tables list the members exposed by CIMKeyframeRange.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the URI of the layer with the active range. Specify a single layer or leave empty to indicate all layers that share the active range name.
    Public Property Gets or sets the active range name. Used to update which range is active.
    Public Property Gets or sets a value indicating whether the range should be all values less than the minimum value and greater than the maximum value.
    Public Property Gets or sets the layer range extents. Each layer range applies to a single map.
    Public Property Gets or sets the method of transition for the layer range extents.
    Public Property Gets or sets the method of transition for the maximum value of the range.
    Public Property Gets or sets the method of transition for the minimum value of the range.
    Public Property Gets or sets the value of the active range.
    Public Property Gets or sets the range relation.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMKeyframeRange.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMKeyframeRange with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMKeyframeRange and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
