ArcGIS.Desktop.Core Namespace / SelectionOptions Class
    SelectionOptions Class Methods
    For a list of all members of this type, see SelectionOptions members.
    Public Methods
     NameDescription
    Public Method Sets the value indicating whether click tolerance is enabled. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets a value indicating whether to keep invisible features selected with a new selection. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets a value indicating whether to save layer and standalone table selection with maps. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the selection color. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodSets the selection fill color. Use this in conjunction with SetSelectionFillIsHatched to set solid or hatched fills as appropriate. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodSets the selection fill to be hatched or solid. Use this in conjunction with SetSelectionFillColor. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets the search tolerance in device units. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets a value indicating whether to display the Selection Chip, when coincident or overlapping features are selected. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Sets a value indicating whether to display the selection graphic during selection. This method must be called on the MCT. Use QueuedTask.Run.
    Top
    Extension Methods
     NameDescription
    Public Extension Method Gets the selection combination mode.
    Public Extension Method Gets the selection method.
    Public Extension Method Sets the selection combination mode. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Sets the SelectionMethod. This method must be called on the MCT. Use QueuedTask.Run.
    Top
