ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphLayer Class / MoveLayer Method / MoveLayer(Layer,CompositeLayer,Int32) Method
A Layer to be moved.
The layer container to move the layer to.
The position specified by the 0-based index. -1 will move the table to the bottom of the specified container. If the index is invalid, the layer is moved to the bottom.
    Move a layer to another position within the specified container. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub MoveLayer( _
       ByVal layer As Layer, _
       ByVal targetLayer As CompositeLayer, _
       ByVal position As Integer _
    public void MoveLayer(
       Layer layer,
       CompositeLayer targetLayer,
       int position
    Parameters
    layer
    targetLayer
    position
    Exceptions
    ExceptionDescription
    The layer or targetLayer is null.
    Invalid container. The layer is not part of this container or one of it's descendents.
    Remarks
    The layer must already be part of this container or one of it's descendents. To move the layer to the root of the TOC use Map.MoveLayer. To move the layer into a group layer from the root of the TOC use Map.MoveLayer.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
