ArcGIS.Core.CIM Namespace / CIMLayout Class
    CIMLayout Class Properties
    For a list of all members of this type, see CIMLayout members.
    Public Properties
     NameDescription
    Public Property Gets or sets the name of the CMYK color profile for a layout.
    Public Property Gets or sets the color model for a layout.
    Public Property Gets or sets the custom properties of the layout. Custom properties are limited to key / value pairs of strings and developers are fully responsible for stored content.
    Public Property Gets or sets the date exported property for a layout.
    Public Property Gets or sets the date printed property for a layout.
    Public Property Gets or sets the color vision deficiency mode that new views of this layout are opened with.
    Public Property Gets or sets a collection of elements.
    Public Property Gets or sets the map series for a layout.
    Public Property Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the CIMPage for the layout.
    Public Property Gets or sets the name of the RGB color profile for a layout.
    Public Property Gets or sets a value indicating whether to simulate overprint for a layout.
    Public Property Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Top
