ArcGIS.Core.CIM Namespace / CIMCustomGrid Class
Properties Methods Events
    CIMCustomGrid Class Members
    The following tables list the members exposed by CIMCustomGrid.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the minimum length of the edge of the mapFrame polygon in page units. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the gridLines of the custom grid. These are limited to ticks, labels, and tabs.
    Public Property Gets or sets a value indicating whether the grid or graticule is visible. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the path to the layer used to define the grid lines.
    Public Property Gets or sets the map grid edges. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the maximum value of the interior angle that determines the edge of the mapFrame polygon. The angle is defined in degrees. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the maximum scale. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the minimum scale. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the name of the Grid or Graticule. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets the neat line symbol of the Grid or Graticule. (Inherited from ArcGIS.Core.CIM.CIMMapGrid)
    Public Property Gets or sets a value indicating whether to use the clip shape of the map (if set) as the grid boundary.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMCustomGrid.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMCustomGrid with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMCustomGrid and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
