ArcGIS.Core.CIM Namespace / CIMStatisticalDataCollectionStandardDataCalculator Class
Properties Methods Events
    CIMStatisticalDataCollectionStandardDataCalculator Class Members
    The following tables list the members exposed by CIMStatisticalDataCollectionStandardDataCalculator.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the DatasetID which is used for getting the information about which points layer will be available and which apportionment methods will be used. For example, for US 2019 dataset it will be ID of the dataset: "USA_ESRI_2019".
    Public Property Gets or sets the Name of the calculator. (Inherited from ArcGIS.Core.CIM.CIMStatisticalDataCollectionCalculator)
    Public Property Gets or sets the variables of the calculator.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMStatisticalDataCollectionStandardDataCalculator.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMStatisticalDataCollectionStandardDataCalculator with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMStatisticalDataCollectionStandardDataCalculator and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
