ArcGIS.Core.CIM Namespace / CIMBABenchmarkComparisonsResultsPaneSettings Class
Properties Methods Events
    CIMBABenchmarkComparisonsResultsPaneSettings Class Members
    The following tables list the members exposed by CIMBABenchmarkComparisonsResultsPaneSettings.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the number of bins in the histogram chart. (Inherited from ArcGIS.Core.CIM.CIMBAResultsPaneSettings)
    Public Property Gets or sets the fill symbol properties of the histogram chart bar. (Inherited from ArcGIS.Core.CIM.CIMBAResultsPaneSettings)
    Public Property Gets or sets the histogram chart subset selection method. (Inherited from ArcGIS.Core.CIM.CIMBAResultsPaneSettings)
    Public Property Gets or sets the histogram chart subset selection method value. (Inherited from ArcGIS.Core.CIM.CIMBAResultsPaneSettings)
    Public Property Gets or sets the histogram variable for the histogram chart.
    Public Property Gets or sets a value indicating whether top/bottom charts should match layer symbology. (Inherited from ArcGIS.Core.CIM.CIMBAResultsPaneSettings)
    Public Property Gets or sets the scatterplot chart type.
    Public Property Gets or sets the field name for the dot size of the scatterplot chart.
    Public Property Gets or sets the field name for the X-Axis of the scatterplot chart.
    Public Property Gets or sets the field name for the Y-Axis of the scatterplot chart.
    Public Property Gets or sets a value indicating whether the regression line should be shown on the scatterplot chart.
    Public Property Gets or sets the variable for statistics in the Summary tab.
    Public Property Gets or sets the direction of the sort in the Results Pane table. (Inherited from ArcGIS.Core.CIM.CIMBAResultsPaneSettings)
    Public Property Gets or sets the sort field of the Results Pane table. (Inherited from ArcGIS.Core.CIM.CIMBAResultsPaneSettings)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMBABenchmarkComparisonsResultsPaneSettings.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMBABenchmarkComparisonsResultsPaneSettings with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMBABenchmarkComparisonsResultsPaneSettings and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
