ArcGIS.Desktop.Mapping Namespace / ImageServiceLayer Class / Select Method
A query filter or spatial filter to perform spatial search.
A combination method.
A time filter only works if the layer is time enabled.
A range filter only works if the layer is range enabled.
A floor filter filter only works if the layer has a defined floor field.
    Select Method (ImageServiceLayer)
    Selects features based upon the specified attribute and/or spatial criteria and combination method. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function Select( _
       Optional ByVal queryFilter As QueryFilter, _
       Optional ByVal method As SelectionCombinationMethod, _
       Optional ByVal time As TimeRange, _
       Optional ByVal range As RangeExtent, _
       Optional ByVal floor As CIMFloorFilterSettings _
    ) As Selection
    Parameters
    queryFilter
    method
    time
    range
    floor
    Return Value
    Exceptions
    ExceptionDescription
    Remarks
    The selection occurs regardless of the layer's IsSelectable state. IsSelectable applies only when interactively selecting features off a map view.
    Features are highlighted on the map and on the table view as a result of this method call.
    If there is a definition query set on the layer, the Select() method will automatically work on the subset of features in the layer that meet the definition criteria. You specify an additional query that will be applied after the layer's definition query by passing valid QueryFilter object for the QueryFilter parameter.
    If the layer has any joins, this Select() method takes that into account.
    Null is returned if the layer does not support selection (see SupportsSelection).
    To ensure maximum robustness, callers should explicitly dispose of the returned ArcGIS.Core.Data.Selection in either a using statement or a finally block.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
