ArcGIS.Core.Data.Knowledge.Extensions Namespace / KnowledgeGraphExtensions Class / RunFilteredFindPaths Method
The knowledge graph on which FFP will be run
The configuration to be used
Example
    Find paths in the specified knowledge graph using Filtered Find Paths (FFP). This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    kg
    configuration
    Return Value
    Exceptions
    ExceptionDescription
    Filtered Find Paths configuration cannot be null.
    Remarks
    FFP allows you to specify many types of pathfinding constraints: you can selectively include or exclude some entities or relationships, specify waypoints, time constraints and per-relationship type traversal directions. You can also specify whether you search for the shortest paths, or all paths, or the lowest cost paths, where the cost is a relationship property.
    Refer also the the Pro help documentation at:
    Example
    Run FFP Using Defaults
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      await QueuedTask.Run(() =>
        var ffp_config = new CIMFilteredFindPathsConfiguration();
        ffp_config.Name = "Run FFP Using Defaults";
        //Origin Entities
        var originEntities = new List<CIMFilteredFindPathsEntity>();
        var poi_entity = new CIMFilteredFindPathsEntity();
        poi_entity.EntityTypeName = "POI";//All entities of entity type "POI"
        poi_entity.PropertyFilterPredicate = "";
        originEntities.Add(poi_entity);
        //Add the CIMFilteredFindPathsEntity to the OriginEntities collection
        ffp_config.OriginEntities = originEntities.ToArray();
        //Destination Entities
        var destEntities = new List<CIMFilteredFindPathsEntity>();
        var supp_entity = new CIMFilteredFindPathsEntity();
        supp_entity.EntityTypeName = "Supplier";//All entities of entity type "Supplier"
        supp_entity.PropertyFilterPredicate = "";
        destEntities.Add(supp_entity);
        //Add the CIMFilteredFindPathsEntity to the DestinationEntities collection
        ffp_config.DestinationEntities = destEntities.ToArray();
        //Path Filters
        ffp_config.PathFilters = [];//Empty
                                    //Traversal
        ffp_config.TraversalDirections = [];//Empty
        //Other
        ffp_config.RelationshipCostProperty = "";
        ffp_config.DefaultRelationshipCost = 1.0;
        ffp_config.DefaultTraversalDirectionType = KGTraversalDirectionType.Any;
        ffp_config.EntityUsage = FilteredFindPathsEntityUsage.AnyOriginAnyDestination;
        ffp_config.PathMode = KGPathMode.Shortest;
        ffp_config.MinPathLength = (int)1;//Min number of relationships in path
        ffp_config.MaxPathLength = (int)8;//Max number of relationships in path
        ffp_config.MaxCountPaths = (int)100000;//Total number of paths to return
        ffp_config.ClosedPathPolicy = KGClosedPathPolicy.Forbid;
        ffp_config.TimeFilter = null;
        var results = kg.RunFilteredFindPaths(ffp_config);
        //TODO process/analyze results
    Requirements
    ArcGIS Pro version: 3.6 or higher.
