ArcGIS.Core.CIM Namespace / CIMMarkerPlacementAlongLineVariableSize Class
Properties Methods Events
    CIMMarkerPlacementAlongLineVariableSize Class Members
    The following tables list the members exposed by CIMMarkerPlacementAlongLineVariableSize.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether to angle the marker to the line. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets how markers are placed at control points.
    Public Property Gets or sets how markers are placed at the end points of a line.
    Public Property Gets or sets a value indicating whether to keep the marker upright. This is only considered if AngleToLine is true. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets the maximum random offset.
    Public Property Gets or sets the largest size of the marker to be placed on the line. The value is expressed as a ratio.
    Public Property Gets or sets the smallest size of the marker to be placed on the line. The value is expressed as a ratio.
    Public Property Gets or sets the number of different sizes of markers to be placed on the line.
    Public Property Gets or sets the offset. (Inherited from ArcGIS.Core.CIM.CIMMarkerStrokePlacement)
    Public Property Gets or sets the numeric pattern that defines the sequence of placed markers and the length of space between them.
    Public Property Gets or sets a value indicating whether to consider individual geometry parts or the whole geometry. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Public Property Gets or sets the starting value for generating a random number. This random number is used by the Randomization property to determine which size a marker will receive. This is only used if the VariationMethod is set to Random.
    Public Property Gets or sets the order in which the change of size in the markers should occur.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMarkerPlacementAlongLineVariableSize.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMarkerPlacementAlongLineVariableSize with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMMarkerPlacementAlongLineVariableSize and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
