| Name | Description | |
![]() | AllowDrapingOnIntegratedMesh | Gets or sets a value indicating whether layer can be draped on integrated mesh. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | AreaOfInterest | Gets or sets the area of interest. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | AreaOfInterestSymbol | Gets or sets the symbol for the area of interest. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | Attribution | Gets or sets the attribution text that appears on a map that draws this layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | BlendingMode | Gets or sets the blending mode for the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | CalibrationMode | Gets or sets a value indicating the preset mode for the simulation layer. |
![]() | Charts | Gets or sets identifier the layer's charts. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ColorRamp | Gets or sets the color ramp for shading the water. |
![]() | ContainWaterInAOI | Gets or sets a value indicating whether water is contained in the area of interest or allowed to leave through the edges. |
![]() | CurrentTime | Gets or sets the current time (in decimal hours) as an offset from the start of the simulation at which to start playing. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | CustomProperties | Gets or sets the custom properties of the layer. Custom properties are limited to key / value pairs of strings and developers are fully responsible for stored content. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | DEMSourceLayers | Gets or sets an array of URIs for the layers that will contribute to the DEM for flood simulation. |
![]() | Description | Gets or sets the description. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | DisplayCacheType | Gets or sets the display cache type. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | DisplayValueRange | Gets or sets the display value range. |
![]() | Duration | Gets or sets the simulation duration in decimal hours. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | ElevationDownscalingFactor | Gets or sets the downscaling factor for loading raster elevation tiles. The cell size is multiplied by this value to change elevation level of detail. The minimum value of 1 uses the most accurate elevation with the slowest performance. Higher values increase the performance speed with less accurate elevation. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | EnableLayerEffects | Gets or sets a value indicating whether to enable any type of effects on the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | EvaporationRate | Gets or sets the evaporation rate in millimeters per hour. |
![]() | Expanded | Gets or sets a value indicating whether this layer is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | FloodSimulationStorageURI | Gets or sets the URI of the simulation data storage that include water sources, barriers and culverts. |
![]() | InfiltrationMaxRaster | Gets or sets the infiltration max raster. |
![]() | InfiltrationRateRaster | Gets or sets the infiltration rate raster. |
![]() | InitialWaterDepthRaster | Gets or sets the initial water depth raster. |
![]() | IsActive | Gets or sets a value indicating whether this is the currently active simulation. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | Layer3DProperties | Gets or sets the 3D layer properties. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerEffects | Gets or sets the layer effects for the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerElevation | Gets or sets the layer elevation. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerMasks | Gets or sets the URIs of the layers used as masks. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerScaleVisibilityOptions | Gets or sets the layer's scale visibility options. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerTemplate | Gets or sets the layer template. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | LayerType | Gets or sets the map layer type. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ManualCellResolution | Gets or sets the manually set cell resolution in map units. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | MaxAOIEdgeCellCount | Gets or sets the maximum number of cells allowed on any edge of the area of interest. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | MaxDisplayCacheAge | Gets or sets the maximum display cache age. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | MaxScale | Gets or sets the maximum scale for layer draw (set as the denominator of the scale's representative fraction). (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | MetadataURI | Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | MinScale | Gets or sets the minimum scale for layer draw (set as the denominator of the scale's representative fraction). (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Name | Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | OverrideWeatherEffects | Gets or sets a value indicating whether weather effects are controlled by the simulation while playing. |
![]() | PlaybackSpeed | Gets or sets the speed to play as a multiplier of the base speed. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | PlaybackStep | Gets or sets the simulation playback time step in decimal hours. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | PopupInfo | Gets or sets the pop-up info. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | RainfallDisplayUnits | Gets or sets the rainfall rate display units. |
![]() | RainfallRate | Gets or sets an array of rainfall rates (in millimeters per hour) over durations (in seconds). |
![]() | RainfallTransitionTime | Gets or sets the time (in seconds) to transition between rainfall rates. |
![]() | RasterizeOnExport | Gets or sets a value indicating whether layer should be rasterized when exporting. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | RefreshRate | Gets or sets the amount of time to wait between refreshing the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | RefreshRateUnit | Gets or sets the units for the amount of time to wait between refreshing the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | Searchable | Gets or sets a value indicating whether or not this layer should be included in the search. This property is honored only by layers that support search. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | SecondsPerSimulationCacheSlice | Gets or sets the amount of simulated time between cache slices in seconds. Only used when UseDefaultNumberOfCacheSlices is false. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | ServiceLayerID | Gets or sets identifier that will be used to identify the layer in server. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ShowLegends | Gets or sets a value indicating whether or not to show legends. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ShowMapTips | Gets or sets a value indicating whether or not the value of the display field or expression is shown when hovering over a layer in the view. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ShowPopups | Gets or sets a value indicating whether or not to show pop-ups. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | SourceModifiedTime | Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | SourcePortalUrl | Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | SourceURI | Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | StartTime | Gets or sets the simulation start time. The end time will be the start time plus the duration. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | SurfaceRoughnessValueRaster | Gets or sets the roughness value raster. |
![]() | Transparency | Gets or sets the transparency of the layer as a percentage. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | URI | Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | UseAutomaticCellResolution | Gets or sets a value indicating whether to automatically determine the cell resolution. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | UseDefaultNumberOfCacheSlices | Gets or sets a value indicating whether to use the default number of stored cache slices. (Inherited from ArcGIS.Core.CIM.CIMSimulationLayer) |
![]() | UseSourceMetadata | Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition) |
![]() | UseVisibilityTimeExtent | Gets or sets a value indicating whether or not to use a fixed time extent for layer visibility. When true, the map time must overlap this extent for the layer to be visible. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | ValueRangeType | Gets or sets the value range type for playing the simulation. |
![]() | Visibility | Gets or sets a value indicating whether or not this layer is visible. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | VisibilityTimeExtent | Gets or sets the fixed time extent for layer visibility. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
![]() | WaterColorizer | Gets or sets the color class breaks for shading the water. |
![]() | WaterDisplayType | Gets or sets the water display type. |
![]() | WebMapLayerID | Gets or sets an identifier that will be used to identify the layer in a web map. This value is present if the layer originated in a web map and facilitates matching the layer back to its origin when updating the web map. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer) |
