ArcGIS.Core.CIM Namespace / CIMMultipartColorRamp Class
Properties Methods Events
    CIMMultipartColorRamp Class Members
    The following tables list the members exposed by CIMMultipartColorRamp.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the ordered list of color ramps (also known as schemes) that are combined to build the multipart ramp. Typically these are continuous color ramps.
    Public Property Gets or sets the color space of the color. This color space is defined by an ICC color profile. (Inherited from ArcGIS.Core.CIM.CIMColorRamp)
    Public Property Gets or sets the proportional weight for each color ramp (also known as a color scheme) that make up the multipart ramp. This allows for ramp to ramp transition at specific weight points.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMultipartColorRamp.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMultipartColorRamp with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMMultipartColorRamp and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
