ArcGIS.Core.CIM Namespace / CIMMultipointGraphic Class
Properties Methods Events
    CIMMultipointGraphic Class Members
    The following tables list the members exposed by CIMMultipointGraphic.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a property set of attributes. Typically set by the layer or element during draw. (Inherited from ArcGIS.Core.CIM.CIMGraphic)
    Public Property Gets or sets the blending mode of the graphic. Typically set by the layer or element during draw. (Inherited from ArcGIS.Core.CIM.CIMGraphic)
    Public Property Gets or sets the graphic's multipoint geometry.
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMShapeGraphic)
    Public Property Gets or sets the placement anchor of the graphic. (Inherited from ArcGIS.Core.CIM.CIMGraphic)
    Public Property Gets or sets the pop-up HTML text. (Inherited from ArcGIS.Core.CIM.CIMShapeGraphic)
    Public Property Gets or sets the reference scale of the graphic. Typically set by the layer or element during draw. (Inherited from ArcGIS.Core.CIM.CIMGraphic)
    Public Property Gets or sets the symbol for the graphic. (Inherited from ArcGIS.Core.CIM.CIMGraphic)
    Public Property Gets or sets the transparency of the graphic as a percentage. Typically set by the layer or element during draw, but not persisted. Change the transparency of layers in the symbol for persistent changes. (Inherited from ArcGIS.Core.CIM.CIMGraphic)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMultipointGraphic.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMultipointGraphic with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMMultipointGraphic and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
