ArcGIS.Core.CIM Namespace / CIMAngleFormat Class
Properties Methods Events
    CIMAngleFormat Class Members
    The following tables list the members exposed by CIMAngleFormat.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the alignment option. (Inherited from ArcGIS.Core.CIM.CIMNumericFormatBase)
    Public Property Gets or sets the alignment width. (Inherited from ArcGIS.Core.CIM.CIMNumericFormatBase)
    Public Property Gets or sets a value indicating whether to display the angle in degrees.
    Public Property Gets or sets a value indicating whether to display degrees.
    Public Property Gets or sets the rounding option. (Inherited from ArcGIS.Core.CIM.CIMNumericFormatBase)
    Public Property Gets or sets the rounding value, whose meaning depends on the rounding option. (Inherited from ArcGIS.Core.CIM.CIMNumericFormatBase)
    Public Property Gets or sets a value indicating whether formatted numbers contain a plus sign for positive numbers. (Inherited from ArcGIS.Core.CIM.CIMNumericFormatBase)
    Public Property Gets or sets a value indicating whether formatted numbers contain digit grouping symbols. (Inherited from ArcGIS.Core.CIM.CIMNumericFormatBase)
    Public Property Gets or sets a value indicating whether formatted numbers contain padded zeros to the right of the decimal. (Inherited from ArcGIS.Core.CIM.CIMNumericFormatBase)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMAngleFormat.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMAngleFormat with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMAngleFormat and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
