ArcGIS.Core.CIM Namespace / CIMRandomHSVColorRamp Class
Properties Methods Events
    CIMRandomHSVColorRamp Class Members
    The following tables list the members exposed by CIMRandomHSVColorRamp.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the color space of the color. This color space is defined by an ICC color profile. (Inherited from ArcGIS.Core.CIM.CIMColorRamp)
    Public Property Gets or sets the maximum alpha or transparency for all of the colors. Can be a value between 0-100, where 0 is fully transparent.
    Public Property Gets or sets the hue at which the color ramp (also known as a color scheme) will end. Values can range from 0-360.
    Public Property Gets or sets the maximum saturation possible for the colors within the color ramp (also known as a color scheme). Values can range between 0-100.
    Public Property Gets or sets the maximum value possible for the colors within the color ramp (also known as a color scheme). Values can range between 0-100.
    Public Property Gets or sets the minimum alpha or transparency for all of the colors. Can be a value between 0-100, where 0 is fully transparent.
    Public Property Gets or sets the hue from which the color ramp (also known as a color scheme) will start. Values can range from 0-360.
    Public Property Gets or sets the minimum saturation possible for the colors within the color ramp (also known as a color scheme). Values can range between 0-100.
    Public Property Gets or sets the minimum value possible for the colors within the ramp (also known as a scheme). Values can range between 0-100.
    Public Property Gets or sets the starting point for the random generation of the colors.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMRandomHSVColorRamp.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMRandomHSVColorRamp with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMRandomHSVColorRamp and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
