ArcGIS.Core.CIM Namespace / CIMRangeDefinition Class
Properties Methods Events
    CIMRangeDefinition Class Members
    The following tables list the members exposed by CIMRangeDefinition.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets ExpressionInfo that contains the Arcade expression that returns a string representing range alias value.
    Public Property Gets or sets the current range.
    Public Property Gets or sets the current range relation.
    Public Property Gets or sets the custom full extent.
    Public Property Gets or sets the end field name.
    Public Property Gets or sets the field name. Used as the start field name when an end field name is set.
    Public Property Gets or sets a value indicating whether or not range is exclusion.
    Public Property Gets or sets the name.
    Public Property Gets or sets a cached set of unique range values.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMRangeDefinition.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMRangeDefinition with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMRangeDefinition and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
