ArcGIS.Core.CIM Namespace / CIMBaseLayer Class
Properties Methods Events
    CIMBaseLayer Class Members
    The following tables list the members exposed by CIMBaseLayer.
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether layer can be draped on integrated mesh.
    Public Property Gets or sets the attribution text that appears on a map that draws this layer.
    Public Property Gets or sets the blending mode for the layer.
    Public Property Gets or sets identifier the layer's charts.
    Public Property Gets or sets the custom properties of the layer. Custom properties are limited to key / value pairs of strings and developers are fully responsible for stored content.
    Public Property Gets or sets the description.
    Public Property Gets or sets the display cache type.
    Public Property Gets or sets a value indicating whether to enable any type of effects on the layer.
    Public Property Gets or sets a value indicating whether this layer is expanded in the contents pane.
    Public Property Gets or sets the 3D layer properties.
    Public Property Gets or sets the layer effects for the layer.
    Public Property Gets or sets the layer elevation.
    Public Property Gets or sets the URIs of the layers used as masks.
    Public Property Gets or sets the layer's scale visibility options.
    Public Property Gets or sets the layer template.
    Public Property Gets or sets the map layer type.
    Public Property Gets or sets the maximum display cache age.
    Public Property Gets or sets the maximum scale for layer draw (set as the denominator of the scale's representative fraction).
    Public Property Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the minimum scale for layer draw (set as the denominator of the scale's representative fraction).
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the pop-up info.
    Public Property Gets or sets a value indicating whether layer should be rasterized when exporting.
    Public Property Gets or sets the amount of time to wait between refreshing the layer.
    Public Property Gets or sets the units for the amount of time to wait between refreshing the layer.
    Public Property Gets or sets a value indicating whether or not this layer should be included in the search. This property is honored only by layers that support search.
    Public Property Gets or sets identifier that will be used to identify the layer in server.
    Public Property Gets or sets a value indicating whether or not to show legends.
    Public Property Gets or sets a value indicating whether or not the value of the display field or expression is shown when hovering over a layer in the view.
    Public Property Gets or sets a value indicating whether or not to show pop-ups.
    Public Property Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the transparency of the layer as a percentage.
    Public Property Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether or not to use a fixed time extent for layer visibility. When true, the map time must overlap this extent for the layer to be visible.
    Public Property Gets or sets a value indicating whether or not this layer is visible.
    Public Property Gets or sets the fixed time extent for layer visibility.
    Public Property Gets or sets an identifier that will be used to identify the layer in a web map. This value is present if the layer originated in a web map and facilitates matching the layer back to its origin when updating the web map.
    Top
    Public Methods
     NameDescription
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Creates a JSON encoding of the CIMObject and its current state. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
