| | Name | Description |
 | ActiveRangeName |
Gets or sets the active range name.
 | AllowNativeQueries |
Gets or sets a value indicating whether the SQL in a definition query can contain native SQL syntax.
 | AutoGenerateRowTemplates |
Gets or sets a value indicating whether to automatically generate row templates from the renderer.
 | BindVariables |
Gets or sets the bind variables.
 | Charts |
Gets or sets the table's charts.
 | CustomProperties |
Gets or sets the custom properties of the standalone table. Custom properties are limited to key / value pairs of strings and developers are fully responsible for stored content.
 | DatabaseRelates | Gets or sets overrides for database relationships as relationship info. By default this property is null. This will contain relationship info elements for those database relationships that have overrides. |
 | DataConnection |
Gets or sets the data connection for the table.
 | DefinitionExpression |
Gets or sets the definition expression that can subset the rows in the layer or table.
 | DefinitionExpressionName |
Gets or sets the name of the active definition expression.
 | DefinitionFilterChoices |
Gets or sets the definition filter choices.
 | Description |
Gets or sets the description.
 | DisplayExpressionInfo | Gets or sets the expression information used for coming up with a string that represents a row or a feature. This property takes precedence over DisplayField. |
 | DisplayField |
Gets or sets the name of the attribute field that will be used as a label that represents each row in the layer or table. The display field must be able to be represented as a string (string or numeric).
 | Editable |
Gets or sets a value indicating whether or not the layer or table can be edited.
 | FieldDescriptions |
Gets or sets the field descriptions. Field descriptions for fields may only be written if values are overridden from defaults.
 | FloorAwareTableProperties |
Gets or sets floor-aware properties for the layer or table used in floor filtering.
 | FormInfo |
Gets or sets the form information for the layer or table.
 | MetadataURI |
Gets or sets the metadata URI.
(Inherited from ArcGIS.Core.CIM.CIMDefinition) |
 | Name |
Gets or sets the name.
 | PageDefinition |
Gets or sets the page definition which allows for using current map series page to filter rows.
 | PopupInfo |
Gets or sets the pop-up info.
 | RangeDefinitions |
Gets or sets the range definitions.
 | Relates |
Gets or sets the relates.
 | RouteIDFieldName |
Gets or sets the route identifier field of a route feature class.
 | RowTemplates |
Gets or sets the row templates.
 | Searchable |
Gets or sets a value indicating whether or not this table should be included in the search. This property is honored only by tables that support search.
 | SelectionSetURI |
Gets or sets the URI of the selection set for the layer or table.
 | SelectRelatedData |
Gets or sets a value indicating whether related data should be selected when creating a new selection.
 | ServiceTableID |
Gets or sets identifier that will be used to identify the layer in server.
 | ShowPopups |
Gets or sets a value indicating whether or not to show pop-ups.
 | SourceModifiedTime |
Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed.
 | SourcePortalUrl |
Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal.
 | SourceURI |
Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal.
 | SubtypeValue |
Gets or sets the subtype value that should be used in the feature layer definition. This property is honored only when feature layer is a member of SubtypeLayer.
 | TimeDefinition |
Gets or sets the time definition.
 | TimeDimensionFields |
Gets or sets the time definition fields.
 | TimeDisplayDefinition |
Gets or sets the time display definition.
 | TimeFields |
Gets or sets the time fields.
 | URI |
Gets or sets the URI of the definition. Typically set by the system and used as an identifier.
 | UseSourceMetadata |
Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project.
 | UseSubtypeValue |
Gets or sets a value indicating whether or not the SubtypeValue should be used.
 | UseVisibilityTimeExtent |
Gets or sets a value indicating whether or not to use the visibility time extent. When true the map time must overlap the visibility time extent for the table to be visible.
Gets or sets the visibility time extent.
 | WebMapTableID |
Gets or sets an identifier that will be used to identify the standalone table in a web map. This value is present if the standalone table originated in a web map and facilitates matching the standalone table back to its origin when updating the web map.
