ArcGIS.Core.CIM Namespace / CIMStandaloneTable Class
    CIMStandaloneTable Class Properties
    For a list of all members of this type, see CIMStandaloneTable members.
    Public Properties
     NameDescription
    Public Property Gets or sets the active range name.
    Public Property Gets or sets a value indicating whether to automatically generate row templates from the renderer.
    Public Property Gets or sets the bind variables.
    Public Property Gets or sets the table's charts.
    Public Property Gets or sets the custom properties of the standalone table. Custom properties are limited to key / value pairs of strings and developers are fully responsible for stored content.
    Public PropertyGets or sets overrides for database relationships as relationship info. By default this property is null. This will contain relationship info elements for those database relationships that have overrides.
    Public Property Gets or sets the data connection for the table.
    Public Property Gets or sets the definition expression that can subset the rows in the layer or table.
    Public Property Gets or sets the name of the active definition expression.
    Public Property Gets or sets the definition filter choices.
    Public Property Gets or sets the description.
    Public PropertyGets or sets the expression information used for coming up with a string that represents a row or a feature. This property takes precedence over DisplayField.
    Public Property Gets or sets the name of the attribute field that will be used as a label that represents each row in the layer or table. The display field must be able to be represented as a string (string or numeric).
    Public Property Gets or sets a value indicating whether or not the layer or table can be edited.
    Public Property Gets or sets the field descriptions. Field descriptions for fields may only be written if values are overridden from defaults.
    Public Property Gets or sets floor-aware properties for the layer or table used in floor filtering.
    Public Property Gets or sets the form information for the layer or table.
    Public Property Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the page definition which allows for using current map series page to filter rows.
    Public Property Gets or sets the pop-up info.
    Public Property Gets or sets the range definitions.
    Public Property Gets or sets the relates.
    Public Property Gets or sets the route identifier field of a route feature class.
    Public Property Gets or sets the row templates.
    Public Property Gets or sets a value indicating whether or not this table should be included in the search. This property is honored only by tables that support search.
    Public Property Gets or sets the URI of the selection set for the layer or table.
    Public Property Gets or sets a value indicating whether related data should be selected when creating a new selection.
    Public Property Gets or sets identifier that will be used to identify the layer in server.
    Public Property Gets or sets a value indicating whether or not to show pop-ups.
    Public Property Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the subtype value that should be used in the feature layer definition. This property is honored only when feature layer is a member of SubtypeLayer.
    Public Property Gets or sets the time definition.
    Public Property Gets or sets the time definition fields.
    Public Property Gets or sets the time display definition.
    Public Property Gets or sets the time fields.
    Public Property Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether or not the SubtypeValue should be used.
    Public Property Gets or sets a value indicating whether or not to use the visibility time extent. When true the map time must overlap the visibility time extent for the table to be visible.
    Public Property Gets or sets the visibility time extent.
    Public Property Gets or sets an identifier that will be used to identify the standalone table in a web map. This value is present if the standalone table originated in a web map and facilitates matching the standalone table back to its origin when updating the web map.
    Top
