ArcGIS.Core.CIM Namespace / NALocatorDefinition Class
Properties Methods Events
    NALocatorDefinition Class Members
    The following tables list the members exposed by NALocatorDefinition.
    Public Properties
     NameDescription
    Public Property Gets and sets a boolean which indicates whether to turn on or off auto-relocate behavior at solve time.
    Public Property Input classes with an override locator use those locator settings instead of the default locator settings.
    Public Property Gets and sets the maximum snap tolerance.
    Public Property Gets and sets the locator agents.
    Public Property Gets and sets the output spatial reference.
    Public Property Gets and sets the snap tolerance.
    Public Property Gets and sets the snap tolerance units.
    Top
    Public Methods
     NameDescription
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Creates a JSON encoding of the CIMObject and its current state. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
