ArcGIS.Core.CIM Namespace / TimeExtent Class
Properties Methods Events
    TimeExtent Class Members
    The following tables list the members exposed by TimeExtent.
    Public Constructors
     NameDescription
    Public Constructor Default constructor for TimeExtent
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating if the time extent is empty.
    Public Property Gets or sets the end time of the extent.
    Public Property Gets or sets a value indicating if the extent contains an end time. If false the time extent has no upper bound.
    Public Property Gets or sets the start time of the extent.
    Public Property Gets or sets a value indicating if the extent contains a start time. If false the time extent has no lower bound.
    Public Property Gets or sets the time zone definition of the time. (Inherited from ArcGIS.Core.CIM.TimeValue)
    Top
    Public Methods
     NameDescription
    Public Methodstatic (Shared in Visual Basic) Reconstructs the TimeExtent with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the TimeExtent and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
